1989 150hp vro question
crazycajun25
hi all i have a 1989 evinrude 150hp my question is if there is a restiction in the oil line will the vro pump shut the engine off ? i have replaced the fuel lines ,changed filter ,spark plugs ,checked spark ,checked compression and rebuilt the carbs,there is no antisiphon valve the only thing left is the vro pump and oil line
thanks very much for any answers
Captain Jeff
Re: 1989 150hp vro question
If you think you have a restriction there, disconnect the oil line and hook up an anti siphon valve or hand vacuum pump and see if oil is flowing. The newer VROs have a low and no oil alarm but I am not sure that your model has this functionality. What symptoms are you having with the engine?
crazycajun25
hi there
it is the old three wire pump The engine will shut down after start up if you pump the oil primer bulb it will start up again then shut down when the pressure is go off the primer bulb. I just took the pick-up out of the ol tank and the foam filter was partly over the pick-up tube don't know if this would cause it or not
thanks
crazycajun25
don't know about the alarm I took the controls apart and the alarm was melted on one side . I'll have to get a new one before i run the engine again. Have to find out what caused it to melt.Tried the test light on the wires on the engine ,they seem to be alright when grounding the wires
thanks
