SWAPPING FROM 115 TO 85
fireman_103
I have a 1977 Evinrude 115 which number three lost compression and in scared up. I have a 1977 Evinrude 85 that has good compresson but needs carb and powre pack. Will carbs from 115 work with out changing Jets if not do I just have to change the Jest that are viewd from th side only. Also what size wrench do I need to take off fly wheel nut. 1 1/4 is to small I was told it looks like a 1 3/8.
thanks
ezeke
Re: SWAPPING FROM 115 TO 85
It is 1-5/16.
go to brp-evinrude, clik literature, then clik engine diagrams, follow prompt to your engines , and compare parts.
ezeke
You need someone like DHadley or Joe Reeves to tell you what to/can swap. They are different engines as to bore/stroke displacement, etc.
WillyBWright
I get in there through www.johnson.com.
Power pack-probably Yes.
Carbs, probably No. They probably have different throat sizes. Jetting would be purely experimental unless the porting, reed stops, and exhaust tuning are the same as the 115.
jimmbo
Carbs are bigger on the 115
Dhadley
The 115 carbs will bolt on but will probably flow a lot more fuel than is required by the 85. The bore of the 85 is 3 3/8" (3.375") and the 115 is 3 1/2" (3.500").
I've never made that swap so I'm guessing but I'd think the carbs would work, the holeshot might be slower, you might pick up a tad on top and your mileage would suffer. All of that can be overcome with jetting but unless you happen to have a bunch of carb jets it won't be easy.
That being said keep in mind that the carbs don't know what motor they're on, they just flow fuel according to how much air is flowing thru the venturi. The smaller bore and smaller ports might not create enough velocity to be very noticable. It's easy enough to try.
What's wrong with the 85 carbs? If they just need cleaning, it's easy enough to do that.
fireman_103
I have the 85 carbs and will rebuild them. Just trying to take a short cut. Now I have another problem. Number one is not firing. I have changed the coil and power pack and it is still not firing. It will fire the first time i turn it over then stops. The other three are firing but the engine will not start and dont even sound like it wants to. Compression is 95 in all four. Do I need to change stator base? How can I check this.
i'd try another compression guage, 95 is getting to the low side. how long has this engine been sitting.
fireman_103
Motor has been sitting for couple of years. I used the same gauge on a 70 johnson and got 125
fireman_103
I changed the stator base and it is now trying to start. With a 95 compression on all four will that get better with time or should i just not bother using the motor at all.
seedpws
You could try and decarb the motor with seafoam and it might get the compression up.
