shekinah5678
Thread starter- Joined
- Mar 25, 2007
- 41
Hello I have a 1980 mercury 115 that I have a problem with. First off it is fairly hard to start after sitting for a day or so. Usually takes a small burst of starting fluid then it kicks off and goes. No problems getting started after that. The big problem is when I get it out on the lake. First of all, I have to lightly ease it into gear or it dies. Once its going it goes great planes out fast and sounds strong. After a few minutes of running at mid to full throttle it just starts to loose power and eventually dies. I can usually get it restarted but have to ease it back to dock. Then it sits and runs fine while at idle. At the lake I checked to see that the fuel line was not kinked and that the fuel filter was not clogged. Both were fine. I haven't done anything else yet thought Id see if anyone could give me a starting point. Should I have the carbs rebuilt or is it somthing other than fuel related. The boat has sit for a over a year so I know doing the carbs wouldn't be a bad idea. Any ideas would help. Thanks
