Re: 67 9.5 hp johnson fuel pump
Is your existing fuel pump about 1.5" square or is it larger with 5 sides?
The earliest 9.5's had the 5 sided ones. The square shaped ones came later. If you had the square shaped one, this link will help:
http://www.wisnersinc.com/Fishing Info/Rebuilding_fuelpump.htm
It also affirms the Sierra Repair kit number.
I know that either pump works fine, and that the square ones were used from 68 on, but I am not sure about 1967.
The square pumps are available as OMC/BRP #s 382224, 388833, 391638, and 397839 . The OMC/BRP repair kit is 393088 and the Sierra aftermarket repair kit is 18-7823.
8)
