shorty1_wt
- Joined
- Mar 27, 2007
- 3
I am trying to remove the power tilt and trim from a johnson 115 donor, I removed the two large bolts on either side and underneath the engine, also the two screw plates on the lower unit and the bolts holding the steering or w/e to the lower unit, the problem is this, I cannot figure out how to remove this bolt (location pictured below)
here's a closer view
the odd looking nut on top is connected to a rod that goes from the top to the lower unit, this is preventing me from removing the complete steering / TnT assembly / transom mount or whatever it is called. any help as to how to remove this would be greatly appreciated.
