pulling flywheel
cataster
I bought a generic multi-purpose puller for my flywheel on a 1990 Johnson 115 H.P. The puller came with various bolts for the flywheel, but the bolts do not fit. I am trying to determine the correct bolt size for the three bolts that screw into the flywheel. My clymer shop manual does not give the size, but I think the screws should be 5/16" 24 thread. Also, I am trying to find the torque settings for my flywheel nut. Any help would be appreciated. thank you
iwombat
Re: pulling flywheel
1/4 - 20. Make sure to get grade 8 and you'll need some washers or they'll fall through the slots.
iwombat
Ooops - someone else should confirm that. I didn't read your model correctly the first time (1990 15 hp is a little different). I may still be correct though.
cataster
F.Y.I.
33 MM socket for a 1990 Johnson 115 H.P. flywheel nut
100-105 ft-lbs for flywheel nut torque
sweetmarie
F.Y.I.
Not to hyjack but would you know the torque settings for a 1986 175 hp Evinrude , (stator and flywheel), please? Thanks a bunch.
don't know exact, but most are 105 to 120 ft lbs.
sweetmarie
Never mind, I found a site that lists all steel strengths/diameter and their respective torque specs. Thanks anyway.
