Re: mercruiser 220 cc 228HP engine
I'm assuming you are referring to a 305 GM?.....
What year?
You probably need Merc. manual #2....
That is not available online.....:'(
But if you have some specific questions, I will try to help........JK
With the engine in the #1 firing position, the following valves may be adjusted.......
Exhaust-1-3-4-8
Intake-1-2-5-7
In the #6 position
Exhaust 2-5-6-7
Intake 3-4-6-8
Back out the adjusting nut until lash is felt at the push rod, then turn nut until all lash is removed...
This can be determinedby moving the push rod up & down while turning adjusting nut until all play is removed
Tighten 1 full turn....
& that's it.......
This is for a standard rotation engiine, btw........
