Yamaha 30hp 3cyl 1991 advice
Dovekie
Background: Alumacraft 16'7" VT 20" transom with 2005 Nissan 25 l/s e-start remote now all run good with 2-3 person & excellent solo in 1'-2' wind lop 3'-6' long period swell. Ocean use winter & summer. Looking for spare motor & recent purchase 1983 Suzu DT8 (hp) s/s with cyl press. 140/140 easy start idle & run-up in barrel; good telltale apparent little use or damage but otherwise unknown & as yet untested. Requires transom bracket. i have not yet looked at lower end gear oil.
Option now is Yama 30 tiller m/s with cyl press. 130,130,115 on 7 pulls; rptd un-used 8 yr. clean under cowl but not as yet run up, unknown otherwise though seller garage is clean. Advised can test on boat & if unsuitable rtn. Bottom 1&1/2" skeg broken off & propellor was replaced by current owner who says that he ran motor with muffs at least once ea. year for ~1/2 hr & turned on day that i viewed. Asking $800. Model 30MLHR serial 6J8L405853 6M6180
i know that a 30 hp 3 cyl @ 140 lb is no spare & 25 Nissan remote is obviously not v practical to mount in pinch, but consider Yam as pot. main motor & if so req. control box or adapters.
User is not esp. knowledgable in repair (for shame)though have operated var. outboards on s/w ~ 30 yr. Qn here for those who may know is whether ther are any particular concerns wrt this model/yr esp. wrt pot. maintenance or repair &/or specific things to look for. i am concerned abt. 3 carbs vs. 1 age (16 vs 2) & weight (140 vs 120) but think that there are benefits.
Any input here is welcome. Oh yes, i pd $600 for the Suzu & likely have option to sell for same while Yama may not last long & if does there is a hint. Apology for long post.
Thanks
Dovekie
Re: Yamaha 30hp 3cyl 1991 advice
Forget to mention that Suzu DT8 is 1983 model year.
JUSTINTIME
800 is not bad
u might want to de-carb and u might free up a piston ring
Dovekie
JUSTINTIME said:
800 is not bad
Thanks Justintime.
i thought that $800 was decent but so did others cause when i went by last evening after talking to seller at noon he told me that there was a guy waiting for him when he got home & motor sold. In some sense i'm relieved as the boat handles well with the 25 (& 30 upgrade poss. with carb gasket change). Certainly the 8 Suzu will be easier to muscle on in a pinch, so it's bracket time. i did check lower end oil & this fine.
"Everything in life is a trade-off." (RIG)
Sorry abt. the long posts. - Thanks once again.
