Re: 1948-49 3 hp goodyear made by gale
Gas out of the top means the float isn't working or the needle valve/seat under it it not working. Simple fix. Pull the carb and clean it. Start with a clean work area, well ventilated, and arrange the parts in order on a white paper of some sort (I use old newspaper). You can clean it with spray can carb cleaner, but it's better to immerse it and let it soak overnight if you can. If the float is saturated and not floating, the needle valve won't close and you the overflow. Old cork floats can be recoated with spray shellac or fuel-proof dope from hobby shops, as long as it's in one piece. If it's not in one piece you can make another from cork. Might also want to clean the tank and fuel line while you are doing this, again with carb cleaner. Good luck, those are good little outboards. Gale was the generic mfg. division of E-rude/Johnson.
