75 Johnson Problem
highwayman
I have a 75 Johnson on a 16ft mckee craft. it runs great but: When i fire it up it runs great I will take off and its runing like a champ 25 to 30 miles an hour but youll go for a while then youll stop and when you try to go again it wont go. it will only get up to about 4 or 5 miles an hour and thats with the throtle all the way down. Some times this wont happen for long time like usally on the way back. Dose this sound famillar to anyone?
jvaccarino
Re: 75 Johnson Problem
Are the RPMS only going to a certain limit when it slows down? I had a similar problem where I could only rev to 3500 rpm.. due to a faulty temp sensor..
highwayman
Yeah i beleive the rpms are staying low, do you think a new sensor will fix it,and can I change it?
jvaccarino
I believe it's a simple fix.. Only 2 or 3 wires to disco and reconnect. Local marine should carry, probably would come with a manual also.. I would investigate more tho before you take my word for it.. But if the RPMs are not increasing, thats probably the cause..
highwayman
If that isnt the problem what else could it be?
highwayman
It only goes to 3000 rpms, but if i put in nutral and rev it it will go higher. Is that consistant with a bad sensor.
highwayman
just a bump so more folks might be able to help:'(
F_R
Let's start by finding out what year that 75 is. Maks a big difference in trying to figure out what's wrong. Model number?
i.m with FR, start at the beginning, there are a lot of 75's what have you checked?. last time it was serviced?
highwayman
Its a 1981, I just had it serviced and had new motor mounts installed.
F_R
Suspect a bad coil breaking down when it gets warm, causing it to not run on that one's associated cylinder. Are you running QL77JC4 spark plugs? You should be.
highwayman
I will go ahead and get some new spark plugs. How hard is it to change the coil,and is there a way to check if the coil is bad?
if you have an induction timing light available, i'd take it for a run until it starts acting up, the connect the light to the battery, and put the induction pick up, on each plug wire. it will show whats, not firing. coils are simple to replace. just watch where the wires come from, and replace in the right spot. do one at a time. make sure the connections are clean and tight.
