OneFineFiftyNine
Thread starter- Joined
- Mar 31, 2007
- 40
Hello everyone,
Sorry my first post has to be a tech question. I just got my first boat, a 1970 Larson 185, with a Mercruiser 4 cylinder I/O. It supposedly ran, according to the guy I bought it from, a month before I got it. I know I should have asked him to run it for me, but since I got the entire rig for $100, I didn't want to be too picky, and the engine does look pretty clean considering it's age. The oil is also fairly clean.
I'm fairly mechanically inclined, I have a lot of experience with car engines; rebuilt quite a few. This, however, is my first boat.
When I go to start it, the engine turns about an inch and there is a "thunk" and it doesn't go any further. When you release the key, the engine turns back to where it was previously. When you do this, the outdrive turns to one side as if you were turning the steering wheel.
I replaced the starter this morning due to an unrelated issue, so it is brand new.
I have tried moving it in and out of gear, always getting the same result. Anyway, I was looking for advice on what to do next. It is a physical impossibility to put a socket on the crank pully with a large breaker bar for two reasons: 1) there is no nut on the crank pulley, and 2) the large motor mount in located directly in front of it also renders this impossible. I know I could remove the starter and turn the flywheel with a pry bar, but if the starter can't move it further than inch, I doubt I will be able to either.
I appreciate any info or pointers. And if you're in the Brevard county area, there might be a case of beer with your name on it if you can get the motor started. 8)
Brian
V8PunkRocket@aol.com
Brian
