Boomyal
Thread starter- Joined
- Aug 16, 2003
- 12,072
Seems this was a question not too long ago. I just popped of my left risor because my risor to 'Y' boot developed a little pinhole in it while I was winterizing it. I have little clearance around the risor and was unable to loosen it with the dead weight hammer.
Today, I took my modified chisel and was able to pop the risor off the manifold, then pry it up out of the two stepped shaped boot.
The risor used a metal gasket between two gaskets. The metal shim gasket blocked off the water flow, up thru the risor. On the forward water slot. there was a very small hole thru the shim gasket.
I have not taken off the right side yet but why are all the water passages to the risor blocked. The whole mess was packed with sand. The boot was not cooked but had multiple cracks and one that went all the way thru the boot.
I know that the side of the risor, on both, sides is fed with a hose coming back from the thermostat tower. What gives. Why might all this sand have accumulated when I just should have been blown out thru the large water slots that were blocked by the metal shim?
