Re: Exhaust cover plate gasket sealant?
The manifold gaskets on the newer motors are probably impregnated with a sealer/glue already.
Proper preparation of the sealing surfaces, and following torque specs, are more important.
One tip, if you're running in salt, a very thin coating of Permatex #3 Aviation-type gasket dressing on the bolt threads will prevent salt buildup around the bolts and make it a lot less painful if you ever have to service the manifold again.
HTH...........ed
