i need to know if anyone out there knows what the cross reference is for the 3.0
Re: i need to know if anyone out there knows what the cross reference is for the 3.0
Agreed on the displacement numbers but for quick conversions, there are 61 cubic inches per liter. I also agree that the 3.0 is a different engine than the 2.5 but not as much as you would think and I'll get into that later. As for the timing gear set, GM is not one to re-invent the wheel when it?s not necessary to do so and therefore they use existing designs wherever possible. If the 3.0 uses a cam gear that's pressed onto the cam I still feel there is a fair chance it?s the same gearset as the 2.5 used in cars. I suppose most wrenches would assume I'm talking about the front drive 2.5 (and although I don't dismiss that engine either) I am speaking about the longitudinally mounted 2.5 that was born in 1961 and found its way into the then new Chevy II and in later years the Olds Starfire, Pontiac Astre, and Buicks equivalent. That block was changed to accept the front drive train so bellhousings don't match. The original 2.5 has the original small block V8 bell housing pattern. Granted, the engine has been marinized and industrialized in various forms and obviously modernized over the years including the changes you indicated and depending on application all versions cannot be interchanged. . All I suggested is that he try a direct comparison of the gear sets. It costs nothing to possibly get lucky. Using the term Marine or Industrial engine while technically correct, does not mean that engine did not start its life back in 1961 or that it didn?t have an automotive heritage. Let?s look at some pictures. The first is the timing gear setup on the pre-front wheel drive 2.5 (and it really is no different on the front drivers). Does it bear a resemblance to the 3.0?
Here is a picture of the current 3.0 right from the GM Marine web site. Pay attention to the lifter galley covers, the distributor location, oil filter location, fuel pump location and motor mount bosses and the valve cover.
And here is a picture of the pre-front drive 2.5. All of the items referenced above are in the exact same location on this engine. Does that mean the engines are identical? Of course not but it bears witness that these two engines share a common origin. Just as the original 265 V8 does not resemble the last 5.7?s in every respect, the blocks indeed shared a common origin. And just like the 3.0 those small blocks were ?Industrialized? and ?Marinized?.
Once again, we are picking at quite minor points but to call the 3.0 an Industrial or Marine engine is a stretch as the only thing that earns it that reputation is its displacement. The same applied to the 2.5 marine engine. It still started life as a car engine. There are very obvious part differences in these engines, but for certain items there very well may auto equivalents. Items like cam bearings, push rods, rocker arms, core plugs, perhaps oil pumps depending on oil pan useage, and even some gaskets are the same (perhaps not by part number) but by use. Composition makes a part number different. It does not always mean two different part numbers can?t interchange. As for the pictures -- circa 1977. I can also provide the same pictures back to 1963 and there will be little if any difference.
Silvertip,...... I dispute Nothing you've noted in your explanation post......
RICH asked,.........
help me i need to know what the cross reference number is for the timing gears for a 1988 3.0 omc to the gm 4cyl engine
You Replied,.......
Take your old gears with you to NAPA and tell them to pull a timing gear set for a 2.5L Chevy of the same year as your engine.
You'd end up with a timing set for the 2.5l motor that Chevy has been putting into small Cars,+ Trucks for 30 years......
Which is Not the Same 2.5l that your post so well explains......
While Chevy does like to use common parts,....
If that timing set IS in fact the Same,........ It'll be the ONLY Common parts between them.........
If I was going to go trying to Mismatch,+ Will Fit it,.......
I'd grab a timing set for a 250cid Chevy I-6........
Which is the Granddaddy of Both the 2.5l,+ the 3.0l Marine / Industral motors.......
The Odds are Much Higher for a Match........
I'm Not saying that NAPA can't get, or doesn't list the Gear Set for the 1988 3.0l OMC / Chevy..........
It's just listed as N/A in the NAPA Marine catalog sitting here at my desk......
Please don't read more into this discussion than you need to. We are talking engine family here and just as the original 265 and its variants all the way to the 5.7 were very different engines from a part number perspective, they were all from the same family. Because the part number for an intake manifold is different year-to-year for example, does not mean it does not interchange. If you selected the I6 to make a cam gear match that would indeed be appropriate as well. It too appeared first in the 1961 Chevy II at 194 cubic inches. But by 1988 it, the 230, 250, and 292 variants were gone from the automotive/truck scene whereas the 2.5 was not. So chances of finding the timing gear set for the I6 in a 1988 auto parts listing would not turn it up. The 2.5 was also ending it's tenure about that time as a front driver configuration but as I said, I wouldn't dismiss that timing gear set being any different than any other version of the engine you would likely still find a listing in 1988. As I said, all of this was only a suggestion and it requires a visual comparison of the parts. I certainly hope this is taken as a friendly discussion about the real origin of the 3.0 and nothing more. If you really want to get a heated discussion going about engines, just ask the question who had a V8 first -- Ford or Chevy. Just be careful where you put your money. I get a lot of free beer over that one. Cheers.
Ayuh,....... Nothing More than That......
That would be Chevy,.... Back in the Early 1900s..... Long before the Ford Flathead......
Congrats! 1917-18-19 to be exact. And it was overhead valve engine to boot.
Ayuh,...... This is Still Wrong........
It took me some Serious Digging,...... But this is what I found.......
The Little 4 cylinder that the Marine /Industrial motors were based on was discontinued in the Mid-60s.........
The 2.5l that you Insist is a viable fit is Actually Originally a Pontiac motor....
It's the 2.5l motor that Chevy used for the rear wheel drive Cars,+ Trucks up til lately........
It is NOT a parts candidate for the Marine / Industrial motors that We work on..............
180shabah
Bondo is right on this one. The 2.5 (151) that GM had been using for the last 25+ years was a pontiac engine, while the 2.5 (153) that merc used was a cheverolet engine.
