Re: 1990 90 hp Evinrude Starts w/choke but will not run
ok, it's this simple. seafoam is not going to clean a gummed up carb, which you have, living in Fl. it takes very little time for gas in carb to evaporate, and leave the scum. the only solution to your problem, is to disassemble, soak all metal parts, clean all plastic parts, remove jets, and clean orifices. then reassemble with a rebuild kit. don't blame the family, it's from lack of use. also change the impeller, before you burn the motor up, from running hot. after you get everything clean and running, seafoam is recommended to keep it that way.
