I will be painting an aluminum 22ft cuddy, the boat will reside in a freshwater lake and will be in a slip for 6-7 months. Do I need to paint with an official antifouling bottom paint?
From what I can tell the antifouling bottom paint helps prevent corrosion in salt water and also makes it easier or even prevents growth on the bottom. I am not really worried about growth, I can wipe down every once in a while with a wet rag while swimming.
So can I use the same paint that I would for above the water line? It is cheaper, it will allow me to paint the boat all at once, and comes in multiple colors. I read everyone saying to use a bottom paint but am not sure why. Will the other paint flake off if it sits in the water?
Second question
When stripping the aluminum I noticed some of the seams on the boat between two different pieces of aluminum had a red colored rubbery caulk. I assume this was used to help keep out leaks. What should I use to replace it with? Should I use gluvit or a 3m product?
Thanks a ton, you guys are great!
Gazelle
Second question
Gazelle
