5.0 backfiring thru carb
cooter2506
5.0 Mercruiser 1988. I haev backfiring thru carb. Timing is close. Use the thumb over the #1 cylinder method. New cap, rotor, plugs and wires. It has Thunderbolt 5 Ignition system. Not sure what it could be. Rotor is at #1 cylinder when at tdc so im confused. Any suggestions?
Don S
Re: 5.0 backfiring thru carb
You don't set timing by putting your thumb over the Spark plug hole, you only find if that piston is coming up on comperssion stroke or not. That doesn't tell you anything about the timing.
Does this thing run?
TB5 Ignition? 88's didn't have it!
So you aren't the only one confused.
Ayuh,........
And Backfiring thru the Carb is Usually a Fuel Delivery Issue..........
Don S
Do you have the plug wires in the proper location. #1TDC for the compression stroke and then going from that point in the proper rotation and sequence all the way around?
cooter2506
Yes I have the correct order of fire on the Distributor. I used the thumb test just to make sure the #1 piston is comming to tdc as the rotor is hitting #1 on the cap. And you are correct 88 had a Thunderbolt 4 system mine is actually a 1998 with thunderbolt 5. Sorry for the confusion.
cooter2506
Sorry it doesnt run when it backfires I stop cranking. So I cant even set the timing properly
You really need to double check your spark plug wire routing.
cooter2506
I have doen that many times but in mass confusion I will check again by pulling all wires of and placing them on the correct plug. Thanks
Was the engine running before you made all these changes? Why did you need to readjust the timing? Did you pull the distributor?
cooter2506
Did bot pull Distributor. Only cap. Set cap in proper location. ENgine ran before. This is an engine swap out. Mine was shot swapped it with a rebuilt one. When I was hoisting from my truck I cracked the distributor cap so i installed a new one.
Don S
Did you replace the rotor also?
cooter2506
New rotor, cap, plugs and wires
SuperNova
1-8-4-3-6-5-7-2 clockwise. Start with the terminal the rotor is pointing at when #1 is on TDC compression. It sounds like you are one terminal too advanced.
cooter2506
Removed all wires and redid plug wiring according to clockwise rotation and the intakemanifold numbers. Still backfiring. Sorry for being a pain but getting very frustrated and hate to take it to a marina for service.
SuperNova
If it ran before and all you did was replace the distributor cap and related components and now it doesn't run....that kinda points you in the direction you need to look. You are overlooking something. I suggest you bring #1 up to tdc on compression, remove the dist cap and see exactly where the rotor is pointing. If you use the thumb method you will feel air twice from the cylinder--once on overlap and once on compression --the compression pulse is a lot stronger. Then line up the timing marks on the crankshaft balancer and the timing cover- then look at where the rotor is pointing. I really think you're just a little off with your timing. Or you damaged the distributor more than you think you did.
Don S
Look at your rotor. Count the number of openings in the metal ring. Should be 8, bet you money you have 6.
