Re: Power Packs
Gary..... The engine is indeed a 1985 115hp Evinrude, a good design. However as with anything mechanical, problems develop.
The spark plugs should be Champion QL77JC4 plugs gapped at .040. What is the compression on the individual cylinders? Standing in back of the engine, facing it, the cylinders are numbered as follows.
2......1
4......3
With the spark plugs still removed, check the spark..... it should jump a 7/16" gap with a strong blue lightning like flame... a real SNAP! Does it? If you don't have a spark tester (and I suspect you might), the following may be of some use to you.
Spark Tester - Home Made
(J. Reeves)
A spark tester can be made with a piece of 1x4 or 1x6, drive a couple nails through it, then bend the pointed ends at a right angle. You can then adjust the gap by simply twisting the nail(s). Solder a spark plug wire to one which you can connect to the spark plug boots, and a ground wire of some kind to the other to connect to the powerhead somewhere.
Using the above, one could easily build a spark tester whereas they could connect 2, 4, 6, or 8 cylinders all at one time. The ground nail being straight up, the others being bent, aimed at the ground nail. A typical 4 cylinder tester follows:
..........X1..........X2
.................X..(grd)
..........X3..........X4
If all of the above checks out okay, then I would strongly suspect fouled, clogged, gummed carburetors. Let us know what you find.
