Can't seem to get my lower unit off.
Tucker 07
I just purchased a 1994 Spectrum 17 dominator. It came with an 1994 force powered by mercury 70hp. The boat has been setting up for about 4 years. So I knew I had some problems but I was willing to try them. I ordered a alot of tune up parts. Well I have to say. I ordered most of my parts off of iboats and they have been great. According to UPS I should receive my parts tomorrow. So today I drained all the gas out of the tank. I put fresh gas in an a new gas filter. So I decide to try and start the motor. I primed it up and hooked my water hose (hose line for us cajuns). Well it fired up in no time. I was suprised it started up so well. But it wasn't peeing. So I tried to prime the waterpump up by spraying water into my pee hole. It still want pee. So I tried to take my lower unit off to look at my water pump impeller. I took off the four lower unit screws and it want come off. How do I go about taking it off? And also my carb leaked gas out of this little hole on the left side of the carb.(left side = looking at sraight in front of the engine.)
So I guess it must be some kind of float stuck. But my trim motor is broke. It should be in tomorrow. So my engine is jacked up high in the air facing down. It might play apart in the leak. I don't know.....
Thanks and sorry so long. I'm just a poor ole cajun boy tring to fix things myself before spending money.
Tucker
byacey
Re: Can't seem to get my lower unit off.
The "Mercury" forum is one above this one. Probably folks there would better know what your talking about.
roscoe
Yes, tilting the motor can cause the carb to leak.
Keep an eye on it.
The lower unit:
Shift into forward gear.
Take a Sharpie marker and draw a line across the jam nut, coupler nut, and shift rod. This will help you when you re-install, and try to adjust the shift rod.
Loosen and separate the jam nut and coupler nut on the shift rod, which is about 8 inches down the starboard side, right next to the trim pump.
Remove the trim tab above the propeller.
Remove the hidden bolt up in the trim tab pocket.
Remove the 4 bolts on the sides of the lower unit.
