Re: 5 HP wards sea king impeller
Your 5D10 model has a neutral clutch and the pump is in the 1st bulge above the cavitation plate. Unclamp the neutral wire at the lever. Then remove the 4 bolts at the bulge. See the 1/4" thick plate at that place? Drop that plate down with the lower unit and remove from motor. The neutral wire will come with it. Don't worry about getting it back up in there, it feeds up through a tube.
Now, separate the 1/4" plate from the lower unit for access to the screws that hold the water pump cover to it. The rest is obvious. The problem is, they don't make that impeller any more. But you can use one for a 5.5 or 6hp Johnson, part number 277181, by reaming the hole oversize enough to go over the drive shaft.
WARNING! If the end of the neutral wire is frayed, don't pull it down out of the tube. You'll have a devil of a time trying to get it back up. But there is a way. Check back here for further advice if that is the case.
