At the end of last season the power trim didn't work at all.With some raps it worked but some times got stuch.I could hear the noise of the motor but the stern drive didn't go up or down.I took the pump out and dissasembled to look first the brushes.The one wasn' t properly positioned.I fixed it .I performed the tests described at the manual.Up to here everything OK.
But,
When I took out the 8 screws of the valve body out and open it apart from the oils a tall cap and a screw exactly the same with 8 screws appeared from nowhere. Ok the tall cap was easy to find its place but the screw? I read all the manual but nothing.The only place i didn't searched is bellow the hydraulic mechanism as the manual didn' t refer anything about it.So i reasembled the unit believing that this screw is useless!
My problem now.Checking again with the battery directly to the motor terminals and a wire to give +12V to the solenoid:
the one cylinder did move the other not.I did the process to take the air out but nothing.It's characteristic the sound of the one cylinder trying to push the other.Grrrr, Grrrr.
What am I doing now?
But,
