Re: where is the power pack?!
ezeke explained where the one powerpack is on your engine,it's good advice to have a manual to use especially when you forgot where something went(in this case a wire connection)However,if you first DISCONNECT the BATTERY,draw a diagram of what you see inside the cover of the power pack locating the wires and their locations,you should be able to do it without need of a high priced marina.Not all of us have the afforability to run to a mechanic each time something goes wrong,and this forum has saved hundreds of thousands of dollars I'm sure to boaters willing to take on a project.Your engine is a very early engine using a powerpack,since then the outboard industry has grown beyond the ability of many "backyard mechanics"a few yrs after your engine they did develop a system of 2 packs and also the ease of simple plugs thus doing away with the worry of wich wire goes where,but you will find these wires are color coded and have a specific terminal where they attach
