Just floating!!!!!!!Need HELP
Boats.com
I have a 1965 6hp seaking motor that i cant get started. This motor has plenty of spark but will not run . I even tried taking the plugs out and giving it a shot of eather straight into the cyclinders then replacing the plugs . I cant even as much as get a hit out of it. It has between 55lbs. and 60lbs. of compression, I was told it would not start with less than 90lbs. of compression. Is this true, and if not do I need to over haul this motor. If anyone has any suggestions to get me and my son back to fishing on the waters it would be greatly appericatied.
WillyBWright
Re: Just floating!!!!!!!Need HELP
60 seems to be the threshhold. There and lower doesn't seem to pull from the carburetor. I'd pull the head and hope for a bad gasket. That motor should have compression in the 80-100psi range.
The paint on the powerhead will discolor when overheated. Tan means it overheated. Pinkish tan means it's pretty much toast.
Boats.com
Re: Just floating is in the past
WillyBWright just wanted to get back to you and anyone else that had suggestions for me.I had a buddy come over and took a look at my motor and I told him I was getting fire but not through the plugs,he asked if I had tryied to file the points to see if it would help any low and behold it worked:cool: ...Im back up and running again thank god ...Me and my son went out the same day and he caught his first stripper bass it was close to 4 lbs. wished everybody could have seen his face then...well thanks again willy for the input if I can help you in any way with any problems feel free to contact me ... thanks Charles.
WillyBWright
You wouldn't happen know a cheap dentist, would you? ;)
