#1CATDADDY
Thread starter- Joined
- Apr 23, 2007
- 23
I have a 1991 Seawswirl with the 5.7L OMC and I have been having ongoing issues with shifting(2-3 yrs). Over the fall I put in the shop thinking the mechanic had OMC experience but apparently not as it is acting up this spring again. The ESA was replaced and was working for a while. It was also tuned up
and was actually running OK last winter before I winterized it. The shifter because it was the original and the trim switch went out was replaced and it is still sticking in forward(or reverse) and hard to get into neutral unless I turn off the key,shift then restart. It has also started to idle a bit rough and the shift interruptor switch may be the problem too and now I am hearing talk about the shift cable that all seem to be related so I have ordered a repair manual to start learning how to repair on my own,hopefully, and with the help of the forum. I am also aware now like those before me that it runs great out of water and not with a load. Please feel free to bombard we with more ideas and I will be relying on those with more smarts than I.
