Jons69chevy
Thread starter- Joined
- Jan 23, 2007
- 22
About a year ago I was just getting started with rebuilding a 1989 200hp evindrude motor that the compression was very low on. You (dhadley I beleive) told me about using some Wiesco pistons from a 1993 and newer 200 hp because they were lighter and it would idle better. I just got the engine back together and was having a few issues with it and wanted to verify the part number for the piston. The piston part numbers that I put is were 3143. Is this the piston that you suggested? My mechanic is concerned that the pistons are causing the problems that we have had and He is going to call wiesco tomorrow and check with them. Just wanted to verify the information with you. I know someone will ask so here is the problem. the motor did not want to idle so the mechanic did a link/sync on it and it didnt help. He tried to get it to idle better but with no luck. He did a compression test on it and the compression was about 75 on each on one bank and 75,65,50 on the other bank. The motor only has 3 hours on it. His thoughts are that the compression issue might be causing the idle issue. The cylinders still look very good. We are running it on premix with the vro disconnected (power and oil lines) Any help is appreciated
