Re: A Mercruiser Alpha WILL bolt right up into the Cobra hole!
Yeah.....it's pretty cool.... and it's not just the cutout.....The bolt pattern is the same too!
And if you want to bolt in a Bravo (Like I'm doing as we speak) you only need to drill 2 additional holes and it'll bolt right up too!!
Life is pretty good (unless you actually go out and buy a 460 powered King Cobra!) Then it's good after you bolt in the Bravo!
Don,
you know the weather at Ocean Shores is going to be about the same as KTN without the snow don't you?
Cheers,
Rick
