Erik-The-Red
Thread starter- Joined
- May 2, 2007
- 21
New here, just registered a few minutes ago out of frustration-- I'm having some serious issues trying to find some information that just shouldn't be hard to find! I own a 2001 Glastron 175 SX, with a Volvo Penta SX outdrive. I've always had the fluids changed by a shop, but I've decided there is no reason I shouldn't do it myself-- I'm a fairly handy guy and know my way around a toolbox. Changing the engine oil is a piece o' cake, I bought one of those fancy-schmancy oil suction pumps from Overtons. However, I'm starting to think the gear lube change process is a heavily gaurded ancient Chinese secret-- I've been scouring the web for well over an hour and have found NOTHING that details this procedure for my Volvo! All I know is, the lube gets drained and must be pumped in from the bottom to prevent trapping air in the unit. Ok, makes sense. But then I read about lower units, upper units, and so on, so I don't know-- are there 2 sections of the drive that need to be filled separately? Or does pumping in from the bottom fill everything? And how full is full? (how many quarts?) Also, if you pump the lube in from the lower plug, what keeps the oil from just pouring back out as you pump it in? Are you supposed to use a fill tube that fits snugly in the hole to prevent the oil from leaking out, and then just be really quick on the draw when you need to pull the tube and replace the plug? Another important question-- what gear lube? A local Volvo guy told me to use a synthetic 80/90 GL-5 rated gear lube and all will be well. Is he correct?
Any info would be fantastic, I'm ready to go buy the correct gear oil and get this job done before I start using the boat again this season. I know you fellers have probably answered this same question a bazillion times for a whole gaggle of newbies, but just once more would be really cool. Thanks guys!
