WOT RPM for 1988 120 Evinrude?
rustyscrew
Sorry, my manual is still on order from Iboats. In the meantime, anyone know what the WOT RPMs should be for a 1988 120hp evinrude?
4500?
I am going out this evening to test out the prop that the engine came with, but I think it has too much pitch.
johnson1989
Re: WOT RPM for 1988 120 Evinrude?
I have a 110HP 89 and it run about 5100 to 5300 at WOT
ezeke
Your motor is a big bore looper with a full throttle operating range of 5,000 to 6,000 RPM. It has a power pack RPM limiter set at 6,700 RPM.
rustyscrew
my manual arrived last night and it looks like WOT is 5000-6000 so I guess I am going to aim for 5800. I got some values of RPM and speed that I was going to post once I plot them. stay tuned.
thanks
noelm
I had a pair of those for a long time (untill 2000 when I replaced them) and they are a very powerfull engine and they LOVE revs so make sure you can get to max RPM and do not be afraid to run it there if you want to.
rustyscrew
New Prop for 120 hp evinrude
I was running 12.75 x 21 prop to get this plot of RPM vs Speed. It was too choppy to open it up all the way, but it looked like I was close to maxing out on the throttle.
I had a merc 1400 on the boat before which was 115 hp and it worked great with a 13.75 x 15 (top speed 31 knots). Now I have a little more HP and probably a different power curve so I need to guess the best prop for it.
I don't need much past 30 knots as it is rarely calm enough to run that fast and I would like it to idle at about 1-2 knots (salmon trolling speed). Right now it idles at 3 knots.
Any ideas?
