Tilt leaking
highwayman
The center tilt deal that raises the motor up is leaking fluid,Its on a 1981 75 johnson sea horse. do they have a seal kit for this if so where can I get it and how do I change it?
highwayman
Re: Tilt leaking
dosent anyone know anything about the tilt
mudd_mickey
Re: Tilt leaking
You can look up your motor here and see if they have a seal kit for it.
http://www.evinrude.com/en-US/Accessories/Literature/?popup=true
At any rate, whether that site shows it or not you probably want to call the dealer since it might be the only place you'll find it although don't give up searching the web, you never know.
You'll need your engine model number to look at your diagram and the least it will do is help you become familiar with the parts names and what you're doing.
JMO
Re: Tilt leaking
they do have a seal kit for that this sounds crazy but u need a special wrench but if u have a freind with a dewalt grinder that wrench works great the seals are about 50.00
