BYBUTTERS
Thread starter- Joined
- May 3, 2007
- 13
FINAL POST... Success...finally. Thanks to all for their advice and help. It was a stuck float in the carb and the engine loaded up with fuel and killed her when opening the throttle. But, I found a way to clean the inside of the carb without taking it all apart and rebuilding it. Pulled the fuel line off where it enters the carb and started the engine and burned the gas out of the carb. Then filled the carb via the fitting where the gas line came off of with Gum-Out carb cleaner and let it soak and bubble for a few minutes. Reconnected the fuel line and started the engine. That's all it took. Ran around the lake like a kid with a new toy. By the way, even though this is a 1993 model, it has less than 50 hours on it so I didn't think the fuel pump diaphragm could be bad.
20 HP Merc on pontoon... new gas in tank... new gasoline & bulb but using old fittings to external tank and motor. Starts good, idles good.. but will not rev.. when you open the throttle either fast or slow engine dies. Will restart OK. Can fast idle with cold start lever. Put seafoam in tank. No change yet. It must either be something plugged or an air leak. Don't know what to try.
Help.
Add'l - "gonealong" describes the problem better than I. I have now run engine medium fast idle and sprayed puffs of Gumout Carb cleaner into the carb throat. Changed spark plugs also. I can tie up at dock and put in gear and get maybe 1/3 throttle before it dies out. There is no rough running... it just dies. I haven't dared tackle taking the carb off yet. Last resort for me.
Byron
Help.
Byron
