== Problem==
Rust color and continuous oily discharge while boat is idling. I just got it out of storage!
== Specs ==
Engine: Mercury MerCruiser 5.0L EFI (inboard/outboard) / fresh water cooled
Boat: 2001 Chaparral 196 SSI
== Details ==
I just started my boat for the first time this season (running it out of water with a "rabbit ear" or quicksilver fresh water attachment). The boat started right up and ran perfect, with the exception of two problems:
1) For the first minute, the water expelled out of inboard/outboard was a rusty color. Water eventually was clear
2) While running for about 5min, there was a light shine of oil in the expelled water. The oil was continuously expelled in the water (I saw a constant "stream" of oil in the expelled water as long as the engine was running). I stuck my finger in the expelled water and there was enough oil on top to stain the skin. It smelled like clean oil. It wasn't fuel.
== Did I winterize? ==
No. First year I haven't. But I didn't think I needed to for the following reasons:
a) I drained all water (following the manual)
b) I put in fuel stabilizer
c) Boat was inside a heavily insulated/heated garage/shop
d) Engine was also protected w/Xtreme engine heater
== HELP! ==
1) Does the rust indicate I didn't get all water out? Did I do damage? Is this something I need to address?
2) What explains the stream of oil? Is this normal after the boat has been sitting for 6mo? Is there a bad seal? What should I do?
Any help/advice would be greatly appreciated.
Steve
[Seattle/WA]
== Specs ==
== Details ==
== HELP! ==
Steve
[Seattle/WA]
