'77 Evinrude 115hp Cylinder Goes Bad Quick!
cyberbubba
Hi,
I recently sold my 1977 16' charger deck boat with a 1977 Evinrude 115 hp outboard. I took great care of the engine, added a water/fuel seperator, kept it garaged when not in use (5-6 times per season) and when I sold it is was running great. I drove the boat over 100 miles to the person who wanted to buy it in Grenada, MS. He wanted this to try it out first, so we launched the boat and after a couple of minutes of starting and warming up (first time out after winterizing) she fired up and we ran it for 10 minutes or more at idle and on several runs of 2-3 minutes at full throttle. It ran perfectly, as it always has for me in the past. The buyer was pleased with the performance, and we did the deal. He had a 100 mile trip to get home to Jackson, MS and blew a bearing on the trailer, but other than that got home in one piece. I took a few calls from him later, one where he had wrapped something around the prop and wondered why it would idle, but would die when shifting into gear, sheesh. (thanks for being patient with this long story, but here comes the question)
Here's the problem, a week later I get this email:
"I took the boat to an Evinrude shop to have some preventative maintenance done (new water pump) and give it a general once over (check the electronics, compression and whatnot). They have informed me that the #3 cylinder is not showing any compression and that its going to be a nice chunk of change to fix. They also informed me that this was not a problem that just showed up as something like that typically happens over a period of time.
I am quite disappointed that I purchased a boat in good faith thinking there was nothing wrong with it but on my first run in the water after getting it home and having to fix the trailer the motor dies."
So I write him back and expressed to him that I was sorry for his problems, but as I stated earlier it was running great when I sold it to him. I also warned him that some shops are less than honest and that he might want to get a second opinion. His response follows:
"Unfortunately the # 3 cylinder is toast the walls are severely scarred.. I am having to replace the entire power head (with a warranted used one) at a cost of $1250, plus labour of $250 or so. (this was the cheapest way out as rebuilding the head was going to cost over $3000. In all honesty I had already planned to spend about $500 on getting the carbs rebuilt, the water pump replaced and giving the motor a general thorough going over, but the $1900 total bill I am looking at is not real pleasing to me since they told me there is no way this problem just popped up the first time I put it in the water. I am not blaming your maintenance and upkeep or your additions but you have to wonder if there was a growing problem when you bought it and since you (as a non-mechanic) did not have it checked out properly it just grew while you owned it and unfortunately died the first time I got to drive it.
If you would agree to pay half the cost of the new/used power head and labour ($750), it would give me a satisfaction of not being cheated on my first boat purchase. I guess I should have had the boat inspected by a proper mechanic prior to purchase, but as they say, hind sight is 20/20."
So, finally the big technical questions, since I had no signs of any problems when I sold it, is there any validity in the mechanics claims? What could cause a sudden death of #3 cylinder?
I would really appreciate some expert feedback here.
Thanks,
CyberBubba
F_R
Re: '77 Evinrude 115hp Cylinder Goes Bad Quick!
If something like a broken ring were to have occured, it would be sudden death of that cylinder. Continued running of it would make the damage get much worse, to the point of total destruction of that cylinder.
I'd say it's up to you and your concience. You can be a "nice guy", or you can say "so sue me". He probably won't win in court, but you will have to hire a lawyer. Where is the break-even point?
ezeke
I have had very similar experience with cars and boats. The car problem was the worst in that the buyer kept coming back for more. I told him to bring my car back and I would refund the money that he paid.
No one believes that a 1977 motor comes with a warranty unless they have just paid for a rebuild. So you do as you please, but if it were me, I would offer to refund the money and have him bring the boat back in the same condition that he got it. If he does not accept that, then tell him he is on his own.​
Joe Reeves
His mechanic(s) fail to mention that, as with anything mechanical, a wrist pin bearing, etc could let go at any time..... even on his first trip out, and that would have resulted in what he has described in a matter of seconds. Then there is the scenario that he may have fogotten to add the proper amount of oil to the fuel which would have had the engine running lean, which in turn would result in damage.
Unless there was a mention of some kind of warranty included with the sale, all sales are legally considered "As Is" which lets you off the hook.
His claim of replacing the complete powerhead for approximately $1500/$1600 leaves something to be desired..... sounds high to me for a used powerhead.
I assume by your post that the buyer lives approximately 200 miles away and for you to be absolutely sure that you aren't being scammed, in effect being forced to lower your selling price..... you'll be expected to drive that distance to verify that the truth is being told?
Engine can be running like new one minute and blow up the next.... it happens. That's why there's the clause (somewhere) that states "Buyer Beware." Frankly I'd need to see the damage personally.
jimmbo
It ran during the test drive, he still could have asked for a mechanical inspection before purchase. He chose to buy it I hope the Bill of Sale stated the goods were ' AS IS, WHERE IS"
Personally, I would be telling him something refering to sex and travel
throwback2332
77 motor, $500 dollar carb job, $1250 powerhead, yeah right the motor is not worth that even on ebay. It sounds like a scam. He can part that motor out and by a good (CHECKED OUT) used motor. If you sold it the right thing to do would be refund his money and take it back. But then does he know how to mix oil and gas, was he horseplaying with something???
redfury
This thread sounds awefully familiary to another thread in these forums that I responded to just the other day.
I'll agree will everyone else, it's a 30 year old motor. It ran fine when you sold it to him, and you have to wonder if he put the right oil/fuel ratio in it, or what kind of oil he used ( how familiar was this guy with outboard motors in the first place, being that this was his first boat? ) Don't let guilty feelings get in the way of a sound decision, he's hoping for that. Simply stating that you are sorry that he had problems, but you sold him the boat in good faith that the mechanicals were in sound running order when you handed him the key. Since there is no way for you to have proof positive that he didn't do anything to damage the motor as a novice boat owner, that you cannot take any responsibility.
domint
I'm with Jimmbo. I always insist on "AS IS - WHERE IS" on every bill of sale for anything I sell.
Dhadley
Something doesn't seem right with this whole scenario. First, a used powerhead?? Second, what are you getting for the 250.00 labor? Then, have you talked to the shop at all? Have you checked into their reputation? Did the guy offer to let you have a mechanic of your choice look at it?
SKEETR
I wouldn't worry about a thing, if you can. You went above and beyond to sell the boat in good condition. I agree with the others that the new owner probably did something or didn't do something that caused its demise. If he ran the boat with the prop bound for an extended period of time I'm sure that put alot of strain and heat on the motor. I'd tell him to pound sand and have a nice day.
jonesg
If I was the guy who bought it and it happened to me I wouldn't have even contacted the seller, why make myself look an ignorant man.
At the very most I'd offer to pay half of his money IF he agreed to pay half of what I paid when I bought it.
I don't think I'd even respond, if you argue with a fool no-one can tell the difference.
" as a dog eats its own vomit so a fool returns to his folly."
Wisdom of King Solomon.
ezmobee
You guys are commenting on a 2 year old thread....
