Mercruiser Alpha one (I think) sterndrive with 140 HP engine I/O:
I recently replaced the hydraulic pump/reservoir since the last motor stopped spinning. I guess it was as old as the boat. Engines runs great though!
Anyways, after installing the new hydraulic pump I took the hydraulic cylinders apart to replace the O-rings as there was a leak comming from the cylinders somehow. New ones costs more than the o-ring kit so I wanted to see if I could fix it myself.
I put the cylinders back together, filled the pump with fluid, connected the battery and spun the motor in up direction. Stern drive went up quickly with no problem.
Then I pushed the switch in the down position...motor spins the opposite direction but the sterndrive stayed in the up position. With some curiosity I walked over and tryed pushing the drive down by hand and with little force it moved.
A few more times spinning the pump in the down position and visiting the sterndrive I eventually got the sterndrive down.
A couple more times of that (I was thinking there might have been air in the system) and unscrewing the reservoir vent to bleed air it still dosen't want to come down on its own.
Another thing I noticed...when I got the drive all the way down I can lift it by hand all the way up. But when it's pumped all the way up it stayes up.
So I'm thinking maybee the piston inside those hydraulic cylinders where moving, but the push rods where not retracting along with the pistons???
Did I put them back together incorrectly?
Thanks.
Thanks.
