1958 18hp Fast Twin
Poncate
Hello,
I have a 18hp Evinrude that is not firing on one cylinder. I installed new plugs and fresh gas and still no change. About mid throttle it tries to fire but just sputters. My next plan is to check the resistance on the plug wires and the point gap.
Any suggestions.
Thanks.
:confused:
Re: 1958 18hp Fast Twin
plan on pulling the flywheel and replacing the coils,condensers, points, and plug wires. $136 clean the carb, and have a like new engine. just did my 58 35hp starts first bump w/o choke. laingsoutboards.com has all the parts in stock, usually 3 day delivery.
Poncate
Great advice. Would have liked to hear a little cheaper but should manage.
thanks.
F_R
1958--Guaranteed to have bad (cracked) coils unless somebody has already replaced them. It's possible that's all it needs. Approx $25 each for 2. They have them right here at iboats.
Poncate
$25 sounds better
When I got the engine one of the coils was rubbing on the flywheel magnet. It scuffed the face of it up. I adjusted it back so it was even with the other one but maybe the damage was already done. Could that be the culprit?
thanks again
iwombat
Moving it back may actually be your problem. The sides should be dead even with the outside edge of the coil mount posts.
Xcusme
Like this....make Surface A and B flush....
Poncate
Awsome pic and great advice from everyone. I'll take a look at the coil placement today and let ya'll know how it turns out.
no here's a bad set
Poncate
Finally figured it out. All of the ignition stuff looks fairly new. So I started trouble shooting the hardware.
I took the coils loose to check the underside for cracking and one of the plug wires was not pushed far enough into the coil to make a good solid contact. I made a starter hole with a small tack and made sure it had a solid connection. No more one cylinder for this fast twin.
Xcusme, I made sure the posts were flush, very helpful visual
tashasdaddy, scary pic I'm glad it didn't look like that when I opened it up.
Thanks for all the help and suggestions. It always pays to look at the cheapest thing first.
:D
the scary thing is it actually ran like that. then i lost one. and opened it up. now you know why i replace everything.
Chinewalker
FYI - the $138 tally that was given above was probably for EVERYTHING - ignition, waterpump, carb kit, plugs & hoses. Covers pretty much all the parts that age or can give you hassles...
- Scott
that's everything, it's like a new motor, turn the key and it starts, without the choke, even when cold. 135 compression on both. original brass 3 blade prop.
