problems
mikejr26
i have a 1975 or 76 85hp mecury and i have put the second switch on and when i start it it will run if you hold the key to the star position what is my problem ????
WillyBWright
Re: problems
Are you sure you're wiring it correctly? Are you using the right kind of switch?
Re: problems
Mike, When you say switch, you mean switchbox, correct? Does that motor have a ditsributor or the ADI (distributorless) Ignition. There is a troubleshooting procedure for each type of ignition posted by Clams Canino. You should be able to find it with a search. If not, post the type of ignition, and I can repost Clams' procedure.
Windykid
Re: problems
Sounds like wired wrong or bad switch or wrong type!
