Singer4096
Thread starter- Joined
- Nov 24, 2004
- 5
Hi all,
I recently purchased a 1982 (?) Skeeter HP-120. The engine is a 115HP Johnson outboard that is in good condition. I had the boat in the shop and had a lot of maintenance type work done on it and it runs fine with an external gas tank, but has problems with the built-in tank. The problem I'm having is that the previous owner had the boat sitting up for several years. He cranked the boat regularly, but the gas/oil mixture was old and now there is a significant buildup of what the mechanics are calling 'lacquer' on the bottom of the tank and in the fuel line. I can replace the line, but does anyone know how I should go about cleaning the tank? The tank appears to be some sort of opaque plastic. I'm worried about normal cleaning agents that I might use like paint thinner, etc. since they might damage the plastic. Do I just ditch the tank?
Thanks,
Daniel
Thanks,
Daniel
