Long shaft to short, Johnson 6hp
hwy49
I have 1979 Johnson 6hp and 16 in. transom. I,ve had since 86 and it's runs good. Would i gain power with a shorter shaft motor. It would be better in shallow water. The motor looks like it has extension above the lower unit. Can that just be removed ? What would it require to convert? Would new lower end or expensive parts be needed. Any info would be appreciated, thank you, Dave
F_R
Re: Long shaft to short, Johnson 6hp
To convert it you have to replace the drive shaft with the short version. Then there is the shift rod. I always used to cut off exactly 5" and file a new notch for the connector screw. However, looking at the parts book for '79 they show a kink at the top end of the shift rod which I am unfamiliar with. Looks like that would preclude cutting it off and require changing the rod. Gearcase disassembly required for that. I don't know the purpose of the kink.
