I was wondering what everyone is using for Carb cleaning. I normally use Berimans carb dip and let them soak works great on all others. I have found the suzuki carbs have that white stuff in them often. This may just be because I normally dont see salt water motors but it seems the metal on the suzuki carbs get that white stuff on them every time I see one. A 24hr soak will not get it off. What is the easiest way you all have found to get it off. I even soaked the bowl in a b12 spray stuff the eats everything still nothing. You can scrap it off with your nail but takes forever to get on clean with a pick, air, and razor.
I that white stuff normal on older salt water motors or is just the suzuki metal.
