Re: Black Max 150 has me baffeled
John,
I Just recently replaced the stator. Have you known them to be bad from the factory or did it get fried for some other reason. High speed coil seems to be what I am lacking, could The inner magnet of the flywheel cause a problem with the trigger. When I checked the magnets the outer ones were a lot stronger than the inner one using a screwdriver as a probe. I'm going to try the timing light test, switching the switch box's is no problem if need be. I can't really feel a missing at high speed and all plugs seem to be the same temp when touching them. I agree about the carbs, they dont leak or change speed while pressing the primer bulb. I'll leave them alone for now. What do the 3 coils in the trigger do and would they hamper the strength of the spark to the coils? I'll test the stator with the ohm meter again just to make sure all coils are functioning. I started to doubt myself and rechecked several things including timing and compression which is still at 120/125 per cyl. I'll keep you posted, thanks Kendo!
John,
