redjmp
Thread starter- Joined
- Mar 16, 2005
- 536
So I've put about 3 hours on my 86 115 rebuild (everything 30 over) and pulled the plugs and checked compression and dry I'm getting 125 to 140.
#1-125 #2-135 #3-135 #4-140 #5-135 #6-125.
With a shot of wd40 in each hole everything climbs by 10lbs.
I'm running double the oil so the plugs are fouled, but it seems to run ok especially when I hammer down after it gets on plane. Spools up to 5600 very quickly.
Do I need to keep breaking it in some more and see if the compression climbs on the 2 weak cylinders or should I tear it down and check for broken rings?
