Re: Mericruiser 3.0LX cylinder head bolt torque
I have Managed to get it back together took it out for a spin and she crank and ran good in my yard ( I did have water running thru it)
Lifters rattleing a little
Hit the water she ran good
got out of the no wake zone gave her a little gas Still good
push the throttle to plane her out (Not full throttle)
she went to rattleing like crazy NOT a Knock like i broke a rod but rather like i left a rocker arm way too loose
I shut her down just to realize i left my 5/8 socket at home so i never removed the valve cover
I started it back up same as above but this time i went straight to planing her out NO Noise until it leveled out so i ease into the throttle a little more
noise gets worse then i loose power not alot but very noticable before shutting it down again i took the oil cap off it had alot of blow by and when i shut it down both times alot of dieseling the last time i did not think it would shut off
Has A rough idle but it will fire right up every time you hit the starter like i said earlier no noise at a idle other than a little lifter noise
Any help would be appreciated
