Hey guys, I took the boat out on the lake and after cruising around for a bit, fishing and stuff it started acting like it wanted to cutoff. Finally it did and I couldn't get it started again. I remember it being hard to start at the put -in ramp as well.I removed a plug and checked it for spark (good) and replaced the fuel filter. I believe that it is the fuel pump. Can I just unscrew the line from the fuel pump to the carb. and check it for flow. Maybe there is another technique for troubleshooting this. Could there be other reasons for it not starting. 1984 Mercruiser Inboard 120 hp, 2.5., MCM 120, Serial #6769768. What is the PSI for this fuel pump, and can I put in a Electrical one in place of the mechanical one. I noticed that there is the main aluminum fuel line going from the pump to the carb and also a smaller yellowish clear plastic/rubber line doing the same. I assume it is a vent of some sort. Just trying to figure out how to set this up with a Electrical pump in its place. Thanks in advance. Any help would be greatly appreciated. New to the Boating game.
