I have a 1976 Evinrude 135hp outboard. It has been running good from about a month since i pulled it out of storage. But now when i pump the bulb on the fuel line gas/oil leaks out the bottom of the carburetor. Also when i can get it started it leaks out a lot! And since there is not enough gas getting to it i cant take it out of high idol. When the high idol lever is up all the way it will jump around from 2000-5000 rpm. (It usually high idols at about 4400rpm) I just had the carburetor rebuild, fuel lines replaced, and a new fuel pump and filter put on. I was told it might be water in my fuel causing it to affect the needle?? Any ideas? Thanks
