GM305 1978 temperature problem
Haut Medoc
Re: GM305 1978 temperature problem
****************PROBLEM SOLVED!!!!!**************************
Indeed!When i pulled out the lower unit to check the impeller i realised that I had made a mistake when installing it. Its housing was provided together with a rubber seal
that should be put in a gap between the stainless cap and the top of the housing and i had put it over the top of the housing. Now i have more water from all of the three outlets.The temp.needle doesn't pass the center by any means.
THANKS to all that helped and to the inspirator of this site!
By the way, Haut Medoc ,what does this mean?"Is BIG OIL robbing your your eyeballs out in Greece?...."
It's a joke........:)
How much is the cost of fuel in Greece?.....:D
Do you think they charge too much?.....:eek:
So you are ready for the water?........:cool:
sarantis
Yes!!!Ready for the water!Three months now about 2-3 hours a day to learn without any other help than the internet and all of you how to maintain and repair an old A1 and an old GM305.One month ago i didn't know even how valves work and finally with your help(Haut Medoc,does Medoc comes from MEcanic DOCtor?)I adjusted them myself.Now perfect sound,everything perfect at least at the garden.I hope everything will go fine at sea too.
