stingray6724
- Joined
- May 12, 2007
- 6
I have the above outboard. The VRO was disconnected when I purchased the boat 2 years ago. After $900 spent making sure there would be no breakdown on the water, then replacing the trim motor, steering cable, starter and trolling motor, and all new gauges, another problem has arisen. The motor will start easily, but only run for about 30 seconds (out of the water) unless I pump the bulb on the gas hose. I read an article that said the VRO is a pump and a vacuum. It seems to me that I have a fuel pump issue. The boat ran fine till this year, and I did have it out 2 times but could only get about 25 mph out of it at best.
Can I just completely bypass the VRO totally? If I need to rebuild the fuel pump, as I feel it is the original with no repairs performed it can only help. If someone can pass along information to purchase either a pump or a rebuild kit, with the part number and possibly a retailer, I would be very grateful. I know very little about outborad motors.
Thanks for any help.
