shipwreck
Thread starter- Joined
- Nov 23, 2006
- 263
ok , then motor a 60hp sport four 1967, or 1966?
four cylinder
the #4 wire show rust and the thread in the boot is discolored @ spark hook up.
first i could not get the wire out of the disturber. see pic is there are way without taking apart the disturb to remove wire.
i would like to clean the spark plug wire connect, then test.
note i need someone to tell how , i have a volt meter ( deluxe model)
can it be tested with a volt meter?
it is just this one plug end that looks bad i checked all the others, they are good to go.
can dielectric grease be used in the connect where the boot goes on the spark plug? like in a car spark plug system?
four cylinder
