cntryby493
Thread starter- Joined
- May 13, 2007
- 6
Hi eveyone im new to this site.I own a 1984 70hp Evinrude.It hasnt been out on the water since 2003.I have been doing alot of interior work on it and have redone the whole inside.It took me a while cause i took my time doing it all right the first time.As far as the motor i fired her up an she ran great considering she hadnt been ran in a long time.My concern is the impeller in the inside of it.Im worried that it might need to be replaced.It pumped water out ok when i had the suction cup ears hooked up to the bottom part of the motor.I thought it could have done a little better but as long as it was pumping water out i felt ok.So i think i have decided to replace it myself but need to know if it is a difficult task an want to know if someone can help me out on doing this procedure here.My local marina shops want a little bit to much for this if you ask me in my opinion.So if anyone can give any feed back it will be gladly appreciated. Also is it ok to run 93 octane for the motor?
