4winnsskipper
Thread starter- Joined
- May 9, 2007
- 204
Just wondering here, i just replaced the u joint and exhaust bellows, lubed the u joints and gimbal bearing, changed drive fluid etc. My question is, as im looking at this drive, im under the impression there should be no water in the u-join bellow...but if your not suppose to use a seal/gasket between the drive and pivot housing, what stops water from getting into the u joints!? or is it suppoes to have water in there? im confused i suppose. i also replace the rubber gasket where the water is drawn in by water pump, but no gasket is used elsewhere.......simple/dumb question i know but im curious.
