Merc Alternator trouble?
tdulick
The volt meter on the boat reports varying voltage from 10 volts to about 13, but not related to rpm's. Is this a sign the alternator is starting to fail and shold be replaced? Is there a voltage regulator on the boat?
Don S
Re: Merc Alternator trouble?
There is a voltage regulator, but it's usually built into the alternator. (Depending on make, model alternator)
It sounds like you may just have a loose V-belt on the alternator maybe rusty pulleys eating the belt up?
tommays
Not a lot of info there :confused:
But the alt output should be checked with a hand held meter(DVM) at the battery
It should be in the 13.5 to 14 volt range when the motor is running depending on the batterys current condition
Tommays
tdulick
Thanks for the assistance = The belts are good, and tightened properly, and there is no rust in the engine =compartment - the boat is a 1996, so 11 years old now, so could the brushed in the alternator be wearing out?
Haut Medoc
I'd check the wire connections......
You could pull it out & have it bench tested.....;)
Don S
If all your connections are good, pull the alternator and take it to a starter & alternator repair shop or even many NAPA and other parts stores and have it tested.
They can put a load on it and see if it's working properly.
tdulick
Thanks for the suggestions - I am guessing I can get a meter to check it without taking it out? Any ideas on what kind of meter I need and what they cost?
180shabah
A cheap DVM will only set you back about $10 at radio shack.
Take a voltage reading at the batttery
Should be 12.8ish
Start the engine and take another reading while it is running at fast idle
Should be 13.5 -14
