Can a bad battery still show 12 to 12.5 volts?
I was running the boat (a 1997 Mercruiser 3.0LX) with the muffs on in the driveway the other day and it stalled out on me. I had just finished cleaning it up..and some water had sprayed on the engine a bit. The boat was idling along..but then it just stopped. I haven't been able to get it started since.
The boat turns over, and sometimes will fire up for about 1 second but then it quits as soon as you let off the ignition.
I charged the battery up last night & will test that out tonight. Another thing I noticed is that the 50 AMP circuit breaker seems to be seized up...it says "push to reset" but there is no way that you could depress that thing. I'm assuming this means I need a new one? According to the manual, the starter and ignition system both run off of this circuit breaker...and since the starter works, I'm assuming the circuit breaker connection is still good.
